C GPIO library for Raspberry Pi
Lightweight GPL'd #include for your C programs
I've been developping and using this tiny file for a few years now and it has been already published in 2014 in the french Linux Magazine and Open Silicium, but here you should find a sort of "repository" with the freshest version.
Optimised for size/speed/latency/real-time, then only for convenience. USE AT YOUR OWN RISKS.
Tested on RPI A, B, B+, RPi2 and RPi3. Contributions are welcome.
No picture or illustration because it makes no sense for a very low-level library...
It's originally based on informations I gathered around the 'net at the time, in particular from http://elinux.org/RPi_GPIO_Code_Samples (which borrowed from http://www.pieter-jan.com/node/15 )
This small set of files is a sort of "foundation", I use them for all my RPi projects that interface to the outside world. In no special order and not exhaustively:
This file is also used as a basis for my compact #C SPI library for Raspberry Pi (and others, later)
It's pretty well tested now, it was published in 2014 (https://boutique.ed-diamond.com/gnulinux-magazine-hors-series/789-gnulinux-magazine-hs-75.html) but the limits are understood as well.
I published it here so I have a stable repository for this cornerstone software, but also to motivate me to support the newer chips, and eventually port it to other architectures.
In 2014 I added the "parachutes" (atexit() calls) which is mostly OK for development but if you need real reliability, use the #Discrete watchdog system.
In 2017 I finally added support for RPi2 and RPi3.
Bonus: 2 dumb example programs and 3 tiny bash scripts that will save your @$$
Note: Direct access to the GPIO pins (as well as detection script) requires the program to run with root rights, or as setuid root. Compilation usually uses this kind of script:
sudo ./detect_GPIO_BASE.sh
gcc $GPIO_BASE -Wall -o program program.c &&\
 sudo chown root program &&\
 sudo chmod +s program
I know there are new ways to use GPIOs without root (through /dev/gpiomem) but I'm so used to it that I don't bother, since I run hard real-time SW that need other root goodies...
Logs:
1. How to support the Raspberry Pi 2
2. Damned RPi3 !
3. detect_GPIO_BASE.sh is broken again...
PI_GPIO.c
The file to include.
x-chdr - 4.51 kB - 11/01/2016 at 20:49
Download
detect_GPIO_BASE.sh
Run this to set the proper compiler option (v2, OK for Pi3)
application/x-shellscript - 197.00 bytes - 02/16/2017 at 18:46
Download
test_in.c
A tiny example that polls pin#7
text/x-chdr - 607.00 bytes - 11/01/2016 at 22:01
Download
test_in_out.c
Copies a GPIO input to a GPIO output.
x-chdr - 764.00 bytes - 11/01/2016 at 20:48
Download
GPIO_on.sh
Bash script that turns a given GPIO pin to 3.3V
x-shellscript - 199.00 bytes - 11/01/2016 at 14:30
Download
View all 7 files
  • detect_GPIO_BASE.sh is broken again...
    Yann Guidon / YGDES • 01/07/2021 at 02:38 • 0 comments
    On a Pi 3 with the 2016 script, the failure is even more burning
    Why can't the RPi guys keep a consistent system or at least preserve backwards compatibility ?
    A new script is required, considering the list I recently found:
    #define PI_01_REG_BASE  0x20000000  // Pi Zero or 1
    #define PI_23_REG_BASE  0x3F000000  // Pi 2 or 3
    #define PI_4_REG_BASE   0xFE000000  // Pi 4
    And don't forget that this is the base of the peripherals block, not the start address of the GPIO block. In these cases, it's:
    #define PI_01_REG_BASE  0x20200000  // Pi Zero or 1
    #define PI_23_REG_BASE  0x3F200000  // Pi 2 or 3
    #define PI_4_REG_BASE   0xFE200000  // Pi 4
    thus:
    $ grep gpio /proc/iomem | grep -i -E '20200000|3F200000|FE200000'
    00000000-00000000 : 3f200000.gpio gpio@7e200000
    It's getting tiring to have to rewrite stuff all the time...
    The latest script is :
    #!/bin/bash
    # version 20210107
    export GPIO_BASE=""
    GPIO_LINE=$(grep gpio /proc/iomem) && {
      echo "$GPIO_LINE" | grep -i 20200000 && export GPIO_BASE=0x20200000  # Pi Z or 1
      echo "$GPIO_LINE" | grep -i 3F200000 && export GPIO_BASE=0x3F200000  # Pi 2, 3
      echo "$GPIO_LINE" | grep -i FE200000 && export GPIO_BASE=0xFE200000  # Pi4
    echo GPIO_BASE=$GPIO_BASE
    Now how long is it going to work ?
  • Damned RPi3 !
    Yann Guidon / YGDES • 02/16/2017 at 17:34 • 0 comments
    Trying to turn a LED on with the lib on a RPi3 using the slim 2017-01-11-raspbian-jessie-lite.zip image.
    GPIO_on.sh and GPIO_off.sh work but not the C code.
    The culprit is found easily because detect_GPIO_BASE.sh doesn't return anything (despite being on RPi3).
    pi@raspberrypi:~/ $ cat /proc/iomem
    00000000-3affffff : System RAM
      00008000-007ea673 : Kernel code
      00862000-009901eb : Kernel data
    3f007000-3f007eff : /soc/dma@7e007000
    3f200000-3f2000b3 : /soc/gpio@7e200000
    3f201000-3f201fff : /soc/uart@7e201000
    3f300000-3f3000ff : /soc/mmc@7e300000
    The expected keyword is not found ! Instead of bcm2708_gpio, I get /soc/gpio
    Another thing is that I forgot to enable the device tree... But a keyword can be added:
    grep -E '/soc/gpio|bcm2708_gpio' /proc/iomem
    Result:
    pi@raspberrypi:~/projets/files $ . detect_GPIO_BASE.sh
    GPIO_BASE=-DGPIO_BASE=(0x3f200000)
    pi@raspberrypi:~/projets/files $ echo $GPIO_BASE
    Seems legit... But I still have to test with the device tree.
    20180118 : don't forget to run the detection script as ROOT !
    pi@raspberrypi$ sudo detect_GPIO_BASE.sh
    Raspbian now returns invalid values when run as user:
     $ cat /proc/iomem
    00000000-00000000 : System RAM
      00000000-00000000 : Kernel code
      00000000-00000000 : Kernel data
    00000000-00000000 : dwc_otg
    (I should update my files......)
  • How to support the Raspberry Pi 2
    Yann Guidon / YGDES • 11/01/2016 at 17:39 • 2 comments
    The RPi2 swapped the venerable BCM2835 for a BCM2836. The Peripheral block is pretty much the same (or so we hope !) but the BCM2835 changed its base address. So that's the only thing that seems to matter for now.
    http://elinux.org/RPi_GPIO_Code_Samples#Direct_register_access:
    Note: For Raspberry Pi 2, change BCM2708_PERI_BASE to 0x3F000000 for the code to work.
    My current approach is to provide the base pointer as a compile-time parameter because I write mostly "bare-metal" code for a specific board, which is then embedded somewhere for an indefinite while. I don't do "portable binary code" that gets distributed and executed here and there on all kinds of boards.
    Actually, "simple is best" because the situation is pretty complicated with the current software environment. A pile of legacy code is accumulating... Some distribution provide features that allow detection of the board type and revisions, some other don't. And this depends on the kernel compile flags, as well as the distribution's bells and whistles.
    Another argument in favor of a compile-time parameter is: the pointer is constant and can be optimised, which saves a bit of time and space. Nothing really important but in some cases it can do a little welcome difference.
    More food for thoughts:
    The following is a shameful copy-paste from http://www.airspayce.com/mikem/bcm2835/
    Physical Addresses
    The functions bcm2835_peri_read(), bcm2835_peri_write() and bcm2835_peri_set_bits() are low level peripheral register access functions. They are designed to use physical addresses as described in section 1.2.3 ARM physical addresses of the BCM2835 ARM Peripherals manual. Physical addresses range from 0x20000000 to 0x20FFFFFF for peripherals. The bus addresses for peripherals are set up to map onto the peripheral bus address range starting at 0x7E000000. Thus a peripheral advertised in the manual at bus address 0x7Ennnnnn is available at physical address 0x20nnnnnn.
    On RPI 2, the peripheral addresses are different and the bcm2835 library gets them from reading /proc/device-tree/soc/ranges. This is only availble with recent versions of the kernel on RPI 2.
    Raspberry Pi 2 (RPI2)
    For this library to work correctly on RPI2, you MUST have the device tree support enabled in the kernel. You should also ensure you are using the latest version of Linux. The library has been tested on RPI2 with 2015-02-16-raspbian-wheezy and ArchLinuxARM-rpi-2 as of 2015-03-29.
    When device tree suport is enabled, the file /proc/device-tree/soc/ranges will appear in the file system, and the bcm2835 module relies on its presence to correctly run on RPI2 (it is optional for RPI1). Without device tree support enabled and the presence of this file, it will not work on RPI2.
    To enable device tree support:
    sudo raspi-config
    under Advanced Options - enable Device Tree
    Reboot.
    Since I don't distribute binaries, I don't care about supporting all the HW&SW combinations under the sun. I can relegate the detection to a bash script :-)
    Oh and in an older Raspbian running on a B+, I get the necessary info from a different /proc/ file:
    pi@pi ~/GPIO $ cat /proc/iomem
    00000000-17ffffff : System RAM
      00008000-005bca23 : Kernel code
    20007000-20007fff : bcm2708_dma.0
    20100000-201000ff : bcm2708_powerman.0
    20101098-2010109a : bcm2708-i2s.0
    20200000-20200fff : bcm2708_gpio
    20201000-20201fff : dev:f1
      20201000-20201fff : uart-pl011
    The base address is obtained with the following command:
    $ echo "(0x"$(grep bcm2708_gpio /proc/iomem|sed -s 's/-.*//')")"
    (0x20200000)
    Turning this into a compile-time define is straight-forward:
    $ GPIO_BASE="-DGPIO_BASE=(0x"$(grep bcm2708_gpio /proc/iomem|sed -s 's/-.*//')")"
    $ echo $GPIO_BASE
    -DGPIO_BASE=(0x20200000)
    $ gcc $GPIO_BASE -Wall -o test_in_out test_in_out.c && sudo chown root test_in_out && sudo chmod +s test_in_out
    Then all I have to do is check if the base address has already been provided:
    // PI_GPIO.c line...
View all 3 project logs
View all 6 instructions
Yann Guidon / YGDES wrote 09/22/2025 at 05:18 • point
Got a Pi5.
Not sure when I'll be able to test it...
Yann Guidon / YGDES wrote 10/17/2020 at 02:34 • point
Here we go again with the latest shiny new Pi :
// Location of peripheral registers in physical memory
