Uploaded the final versions. Use it if you can help. Very simple and fast both the assemble and production, compatible with die- & laser cut.
I got a request, to change the design in a way, that it can fit on a 200 mm x 300 mm sheet. This design can't be made from 1 piece, as such the head strap and the visor are in two different files. Useful if you have less material.
I will upload some better images, these were made at my home, without studio.
In Hungary, we have a shortage of PET-G, as such, i needed to create an alternative for PVC, which can't be cut in lasermachine due to dangerous chemicals. The latest design can be produced with normal die-cut method, with a production rate of daily 10k. License is the same (Attribution-NonCommercial 4.0 International (CC BY-NC 4.0))
FILE STRUCTURE:
There are two versions of each file, one for silicon stripe, one for rubber band
IMPORTANT NOTE:
The versions, which are created for diecut, are containing dashed lines, which are folding lines, in case you are using laser, you either need to delete this, or set the laser power down at these lines, to not cut trough the material.
Konrad Klepacki
MasterOfNull
agp.cooper
Thanks for your comment, you could be right, if it was a hermetically closed space suit, where the goal is to separate the outer / inner air, but this is as OPEN SHIELD.
As such it's purpose is to stop flying particles.
Imagine a hole with the thickness of .7 mm, in which you put a .5 mm material, which is slanted, i'm pretty sure you can understand, why particles can't go trough there (We even tested with strong spray, the worst what we experienced, that after 10secs of close spraying [unrealistic scenario], the fluid can slide down on the inner slide of the shield in a droplet, which is still totally fine, since it doesn't contact the eyes).
BUT, let's play with the idea, that something flies trough, the next target would be the strap, again safe.
So no worries, it works really well, right now 6000 doctors are using it, who are super grateful for it.
