Documentation:
- Describe material profiles in more detail.
- Describe automatic material profile measurement, determine *into-air* and *printing* volumetric flowrate data.
- Update section about temperature-limiter.
- Update section about flowrate-limiter.
- Added more pictures and data plots.
Code fixes:
- Auto-temp: fix "workingpoint" commandline parameter, it worked the wrong way.
- Preload: test another way to compute amout of data to pre-download to the printer, simply count small moves.
- Some cleanup.
