Mon Jan 17 17:45:47 CET 2022
Committed the following changes into the next branch on github:
- Python3 port of ddPrint:
- Converting python files with 2to3 script.
- Fix integer divisions.
- Use bytes() and bytearray() instead of strings for binary data.
- Converted scripts and 'ddtool' utility to use python3.
- Ported ddPrint to Anycubic I3M printer:
- Pin changes for anycubic i3m.
- Add support for ATC Semitec 104GT thermocouple.
- Rework temperature measurement: allow different thermocouple types for heated bed and hotend.
- Homing: add support for additional Z1 stepper motor and endstop.
- Homing: implement dual-z homing.
- Adjust getendstops command for the additional Z-endstop.
- Control mainboard cooling fan (anycubic i3m).
- Changed initial baudrate to 500 kbaud, 1 Mbaud is to fast for Anycubic i3m.
- Auto-baudrate: added new printer profile setting 'baudRateLimit' for the Anycubic i3m (it does not work with 1 Mbaud baudrate).
- Rework and cleanup ddPrint scripts: Added workaround for a problem with the linux cp210x driver used for the Anycubic i3m (CP2102 usb-serial chip): avoid reset of printer on device-open (cp210x seems to toggle DTR line even if '-hupcl' is used).
- Other changes:
- Environment: renamed env. var $DDDEVICE to $DDPRINTDEV.
- Firmware build: Set ARDUINO_PORT from DDPRINTDEV environment var.
- Added new command "continuosmove" for testing, allow simple movements of the printer (without homing) for debugging/initial setup. Note: no acceleration and no endstop-check - dangerous.
- Removed unused baudrate commandline switch.
- Cleanup handling of printer-device ($DDPRINTENV).
- Firmware: moved pins include files into its own folder.
- Improved plot_mat_profile.py scipt: use python-argparse, display more information.
