Decided to divide the project into subprojects and design a number of dev boards before merging them into a single board. Start with the sensor dev board, will be equipped with three VL6180X sensors.
Soft on/off dev board with safe shutdown:
A project log for The invisible mask
Reduces self-inoculation and transmission of pathogenic germs. Can be also used for gesture control
