Open Respiration Masks
Produce open source and easy to acquire masks for respirators and ventilators.
Masks are a problem. The automated BCV machines are limited by tubing length. This option gets past that by using the existing valve configuration and two tubing runs to two separate filters preventing the possibility of re-breathing the exhale within a single tube.
Bottom.FCStd
Exhale adapter. Use water from a kettle to soften the mating surface and press it against the mask for custom shaping. Use glue to attach to mask.
x-zip-compressed - 481.13 kB - 04/03/2020 at 04:58
Download
Bottom.stl
Standard Tesselated Geometry - 88.27 kB - 04/03/2020 at 04:58
Download
Top.stl
Standard Tesselated Geometry - 61.61 kB - 04/03/2020 at 04:58
Download
Top.FCStd
May need to adjust for the tubing or masks available.
x-zip-compressed - 109.19 kB - 04/03/2020 at 04:58
Download
