Audio dB-Meter - on diy POV-HDD-Display
Since i could not establish to display the time on this, it shall be a dB-Meter with (no MEMS - it broke) microphone.
jj
The Mic is quite bad in version 0.91. The sample rate is 25 Hz. in the video.
I changed the mic to a more sensitive mems-mic now. The samplerate and dynamic resolution will much higer soon.
NEW: new sample rate is almost "realtime", with 30 ms'ish refreshrate, due to rotation speed of the disk.
POV_HDD_Display.ino
ino - 6.34 kB - 04/05/2020 at 23:09
Download
  • ver.: 0.93 tests
    j • 04/05/2020 at 18:15 • 0 comments
    30 FPS now ! .. the signal samplerate got up to about 1 kHz. The display "passes out" on too loud signals.
    Test a)
    Test b:
View project log
j wrote 04/05/2020 at 23:12 • point
shure. i loded it up here. Its my first project were i used an interupt, because i "had to". i need to work on my documentation skill (:
vishnubob wrote 04/06/2020 at 00:37 • point
i found it!  have you considered adding an FFT to your audio analysis?  are you going to make it stereo as well?  would be cool to paint either side of the disk with each channel.  fwiw, i edited my comment below with an interrupt strategy that might help carve out cpu cycles without messing with your animations.
j wrote 04/06/2020 at 10:28 • point
Stereo/dual channel display would be nice. I got 3 MEMS mics in my ebay-basket i once even characerised my old MEMS-mic (ADMP401) in frequenciy (0-25 kHz)- and angular-dependency (+/-90°) so a FFT could deliver a real dbSPL (real delta of airpressure) maybe shown on a oled-display underneith the disk. I need to look into your interrupt routines.. bc i must learn more about them but i'll put this project back on the shelve for a while. But i'm quite happy the POV display now hase a functional purpose. I will comeback to this project, when the new mic's arrive!
Still got at least 9 projects (4 quite big) without any documentation and i planed to use some/all of the projects for my curriculum vitae linked through a QR code. But the times are not optimal to find a job (;. I hope you are doing well.
vishnubob wrote 04/05/2020 at 22:18 • point
Nice!  Clean build.  11+ years ago, I wrote this:
https://www.instructables.com/id/Hard-Drive-Persistence-of-Vision-HDPOV/
j wrote 04/05/2020 at 22:49 • point
Thanks! Aww, nice!
I think i tumbeld upon this, when i built this platform. I'm quite shure i got some inspiration from your post! (; thanks for sharing with the world. Under the disk there is a magnet glued to it including a counter-weight on the other side. A hall effect sensor triggers an interrupt for percise timing.
vishnubob wrote 04/05/2020 at 23:00 • point
Back then, I got the idea from Ian Smith's write up, but this was one of the second or third projects where I took a high level idea and made my own implementation from scratch.  It's also probably the best job I've ever done documenting anything I've made, lol.
I like the improvements you've mentioned.  Can I take a peek at your firmware?
<edit>
nevermind, found it above.  if you are interested in an alternative strategy, i ended up using two interrupts: one to time the platter, and a second to fire a timer interrupt per pie slice.  the high level platter interrupt adjusts the timer interrupt, which consumes a frame-buffer with page flipping.  this way, your user / effect calculations will not interfere with the refresh timing.
https://github.com/vishnubob/hdpov/blob/master/hdpov.pde
