A lot of pandemic ventilator designs are based on the BVM. This is a concept design of a more compact variation.
Exploded.pdfExploded view of mechanismAdobe Portable Document Format - 161.32 kB - 04/14/2020 at 18:58 |
Hi Bharbour,
thank you for your interest! I've uploaded a pdf with the exploded view.
Thanks for the exploded drawing. How much travel or "squeeze" do you get?
You can change the amount of squeeze by altering the dimensions of the rotating parts. I've drawn the model parametrically so once an optimal squeeze is determined the parts can be updated accordingly. It would be cool to have a way to alter the amount of squeeze in real time, with the motor always completing full revolutions, but I haven't thought of a way.
This is an interesting mechanism. Could you add an exploded view of the parts?
