The project is dirt simple "cement half A to half B" yet yields what I believe to be an effective ppe for use in socialized environments; grocery shopping, commuting using public transportation; basically attending any event that puts oneself in close-contact with others while in an enclosed space. The utilitarian pump/filter/battery arrangement can be harnessed to an ordinary pant belt and worn similar to a "fanny pack"...
A single 3.7V (nominal) lithium cell powers the popular inflation pump sufficiently. As I do not have access to an airflow measurement system, what I claim to be a usable airflow rate was only determined empirically. I'm a 63 year old, capable of jogging a couple miles, so my fresh airflow breathing requirements I assume are average.
I'm able to stay in the hood for over an hour, breathing comfortably, while doing light work, on just one SAMSUNG--18650-26J cell - taking it down to from fully charged to 3.5V in that time. (Discharge cutoff by spec is 2.75V) One cell is apparently sufficient for grocery shopping, even with the luxury of taking your time as you go through selecting items in the store! To ensure safety, I do carry a spare.
Social acceptance in a few shopping trips using the apparatus seems fine. Most are simply curious, some present a thumbs up or take my picture to show friends. No one seems scared or offended and store employees engage me in light conversation.
Variations can of course include a mask based interface to nose and mouth, as I assume one could connect the completed machine part to any breathing apparatus headgear. However over the past few days I've seen the availability of professionally made, filtered face-mask respirators go down on ebay. I can only imagine in the ensuing weeks, such devices will be unobtanium.
Any help, suggestions, comments welcome. I only ask that we please keep them constructive - I realize this is live internet participation and therefore expect some criticisms.
Looks like it wont let me add a .txt or .pdf as a support file, so in the interim I'll put the parts list here;
Potential Hood structure;
Batteries;
Battery holder;
Filter;
Air pump;
Connecting Hose;
https://www.ebay.com/itm/Everbilt-Universal-Corrugated-Dishwasher-Drain-Hose-Kit-6-Feet/202774831121
Glue;
Looks like no field shows up for adding instructions in the normal way, so I'll put them here:
Instructions, like the project, is a W.I.P. Any help clarifying them is appreciated!
1) Using the recommended glue or equivalent, place a large bead - about the width of a stick pen - around the bottom of the filter, just outside of the black foam gasket.
2) Press the glue loaded filter bottom symmetrically about the pump motor intake tube, such that a clean seal is obtained all around the periphery of the filter bottom to the pump impeller
housing. Preference; there's a plastic screen to prevent inhalation of foreign objects; you may choose to first break this out as with the filter in place, this wont be a problem.
Allow glue to dry overnight.
3) Trim the dishwasher hose to an appx 24" length, initially measured from the larger of the two end connectors. Use the one pump adapter end (provided with the pump) that fits snugly
into the dishwasher hose and glue it in place at the freshly cut end. Allow glue to dry overnight. Note: length may vary, depending on the type of mask / hood you're connecting to -
4) Glue the battery holder to the bottom side of the pump motor case. There are vents; be sure to cover these completely with glue, as who knows the efficacy of any seal between the motor housing and the impeller chamber. You only want filtered air to enter the hood or mask. You may put a layer of glue over the on/off switch - in the on position - to prevent any unfiltered leaks through that component. You may orient the batter holder so (+) is facing up, when the machine is worn (same side as pump exhaust port).
5) Crimp-connect the battery holder wires to the DC power wires of the pump. On the pumps I specified, they use some bizarre metal formulation in the wire that doesn't lend itself to a soldered connection - crimp connect is the only way. On my pump, the brown wire is (+) the blue (-).
6) Test the operation of the pump motor / battery connection using an 18650 cell. You may want to run it for a while, to evacuate any glue fumes from the assembly.
7) Fabricate a pair of rubber hoops or bands to allow the assembled machine to be connected to a belt, so it can be worn in a fanny-pack style - behind you for a PAPR hood, or in front of you for a mask.
8) Connect the large end of the hose to the rear input port of your PAPR hood, secure using a appropriate tie wraps or rubber bands. With the filter pump machine and hood in place on your
person, practice connecting the hose end to the pump output behind your back and connecting the battery. Turn it on ASAP and note the cool filtered air coming into the hood.
9) Test the arrangement by wearing it for some time, being careful to note any stress occuring with your heart, lungs or an indication by getting a headache. It should be intuitively
obvious that the use of this is a temporary measure, as the air quality within a hood over time will NOT be as good as breathing normally. Obviously keep it out of the reach of children when not in use.
10) Only after having mastered the experience of using the apparatus; connecting the hose, exchanging the battery, simply being constrained within the confined space of having a
plastic hood over your head with the airflow and noise, you should now be ready to take it outside and into an enclosed space with other people present.
