We adapted the dual design for two Honeywell North filters, or one 22mm ventilator filter. We have only performed quantitative testing with the 3M design yet but will update this log with the results once we've done the others. All three designs are here. We tested the 3M design printed in PLA and coated in XTC 3D coating. We're also printing in e-Rigid PU resin on an EnvisionONE printer (EnvisionTEC). This is a semi-flexible airtight material that should be able to be used without coating. We will confirm and post back after quantitative testing, but prints look very nice!
