By whygee on Wednesday 22 February 2012, 04:00
Today is a big milestone : a tiny implementation of the YASEP has executed tens of instructions !
phase='1' PC=3FE RAM=0000 Result=0000 DST=0 R1=???? R2=???? R3=???? R4=???? phase='1' PC=3FE RAM=0000 Result=0000 DST=0 R1=???? R2=???? R3=???? R4=???? *** releasing reset *** phase='1' PC=3FE RAM=0000 Result=0000 DST=0 R1=???? R2=???? R3=???? R4=???? phase='1' PC=3FE RAM=1009 Result=0000 DST=0 R1=???? R2=???? R3=???? R4=???? phase='0' PC=000 RAM=1009 Result=0000 DST=0 R1=???? R2=???? R3=???? R4=???? phase='1' PC=002 RAM=1234 Result=1234 DST=1 R1=???? R2=???? R3=???? R4=???? writing 1234 to R1 phase='0' PC=004 RAM=4009 Result=4009 DST=1 R1=1234 R2=???? R3=???? R4=???? phase='1' PC=006 RAM=5678 Result=5678 DST=4 R1=1234 R2=???? R3=???? R4=???? writing 5678 to R4 phase='0' PC=008 RAM=1115 Result=1115 DST=4 R1=1234 R2=???? R3=???? R4=5678 phase='1' PC=00A RAM=4321 Result=5555 DST=1 R1=1234 R2=???? R3=???? R4=5678 writing 5555 to R1 phase='0' PC=00C RAM=1117 Result=234B DST=1 R1=5555 R2=???? R3=???? R4=5678 phase='1' PC=00E RAM=0100 Result=AAAA DST=1 R1=5555 R2=???? R3=???? R4=5678 writing AAAA to R1 phase='0' PC=010 RAM=220A Result=5556 DST=2 R1=AAAA R2=???? R3=???? R4=5678 phase='1' PC=010 RAM=330A Result=0002 DST=2 R1=AAAA R2=???? R3=???? R4=5678 writing 0002 to R2 phase='0' PC=012 RAM=330A Result=0002 DST=2 R1=AAAA R2=0002 R3=???? R4=5678 phase='1' PC=012 RAM=2408 Result=0003 DST=3 R1=AAAA R2=0002 R3=???? R4=5678 writing 0003 to R3 phase='0' PC=014 RAM=2408 Result=0003 DST=3 R1=AAAA R2=0002 R3=0003 R4=5678 phase='1' PC=014 RAM=3408 Result=0002 DST=4 R1=AAAA R2=0002 R3=0003 R4=5678 writing 0002 to R4 phase='0' PC=016 RAM=3408 Result=0002 DST=4 R1=AAAA R2=0002 R3=0003 R4=0002 phase='1' PC=016 RAM=1317 Result=0003 DST=4 R1=AAAA R2=0002 R3=0003 R4=0002 writing 0003 to R4 ....
You can find the source code there and play with the parameters :-)
The "microYASEP" is a compatible subset of the usual YASEP but with many limitations, like only 23 instructions (not yet all implemented), 2 cycles per instruction (no pipeline), not even data memory access... It is designed for tiny FPGAs and the core source code takes about 350 lines in VHDL. Data widths are 16 bits but could potentially be even smaller if needed (I'll have to check). I think it will run around 12 MIPS for the first system that will use it, it could be faster but this is useless.
This would not be possible without all the software tools I have written in the last months and years ! I can now assemble and export in hexadecimal or VHDL, create new custom configuration files with a few clicks, or tweak details at will. I have created a new system of "CPU profiles" that goes beyond the basic YASEP16/YASEP32 distinction.
The microYASEP is just one of the several possible microarchitectures possible with the YASEP. Later configurations will be faster, larger and with more features like the multiplier, shifter and memory interfaces... But with one first application and a running, basic core, the whole YASEP design can tune its details with more real-life feedback !
20200409:
I certainly felt proud and it was only the beginning :-)
