This week I was experimenting with unstable robot behaviour, namely pumping a swing:
I tried various strategies like periodically turning robot on one leg, moving leg up an down aligned with swing seat or perpendicular to it. Apparently pumping a swing is quite a complicated process. In practice it is possible to achieve some results with a simple periodic motion. In the video above robot starts moving up and down with a period of 0.6s and decreases period by 2ms every swing. Motor acceleration speed also affects swing pumping so it had to be tuned.
That's interesting that you decrease the period with each pump. I think you did at least as well as the one's using machine learning.
https://www.youtube.com/watch?v=ke6xKwXwFZU
Indeed it is not obvious why decreasing period worked better than increasing in my case as period of swinging increases with larger amplitude. Maybe I was just lucky to guess some resonance causing numbers.
I did watch video you posted before starting my project to get some hints. There are surprisingly few videos of swinging robots.
I might try more scientific approach to swing higher in the future but it might require building a more sturdy swing.
