^1 Setup with RPUno^5
A project log for K3
Latching Solenoid or Relay driver
ronaldsutherlandronald.sutherland • 04/19/2017 at 17:06•2 Comments
K3 With RPUno
Dave Filicicchia wrote 08/31/2023 at 18:08 • point
I am also curious if you made an interface connector for the valve, or just cut off the original connector. It looks like a 2 mm pin will connect to the valve contacts.
Dave Filicicchia wrote 08/31/2023 at 18:06 • point
I am curious how long you pulse the coil for this valve (58874N) to turn it on or off. I want to use this valve in a project as well; remote turn on/off.
