This is a patch-level release which reworks fchannels to be true rendezvous channels which only do one copy for each message sent rather than two, as it did previously, and which does away with the fixed sizes previously set for fchannels. Note that there are some minor API changes associated with this, specifically that fchan-size
and init-fchan
no longer take size parameters.
