This release:
- adds the variable
term-cols, for controlling the terminal columns in characters used bywords,words-in,lookup,lookup-in,more-words,more-words-in,more-lookup,more-lookup-in,dump,dump-halfs,dump-cells,dump-ascii, andedit. This variable defaults to a value of 80. Note thatmore-words,more-words-in,more-lookup,more-lookup-in, andeditalso query the terminal for its width, and use the minimum value of this and the value ofterm-cols. Also note thateditonly uses this to determine whether to display a border on its sides and line numbers; it does not shrink smaller than 64 characters wide. - adds the variable
words-col-width, for controlling the width in columns of each column of words displayed bywords,words-in,lookup,lookup-in,more-words,more-words-in,more-lookup, andmore-lookup-in. This variable defaults to a value of 20. - modifies
picocalc-term::term-consoleto automatically setterm-colsto the width of the PicoCalc terminal emulator in characters when called.
Travis Bemann
