This patch-level release fixes a bug with peripheral disabling in the i2c
module that caused crashes if an enabled peripheral was then disabled, fixes a bug in [if]
/[else]
/[then]
where it did not properly handle EOF, resulting in infinite loops or crashing, and fixes a bug in edit
(the block editor) which caused garbage values to be put on the data stack each time a block was navigated to, eventually resulting in data stack overflow.
