This release:
- adds being able to use UART's other than the default serial console UART as the primary serial console with
uart::uart-console - adds optional support for turning on trapping of control-C and control-T for arbitrary UART's with
uart::uart-special-enabled!; note that this is disabled by default for UART's other than the default serial console UART to avoid breaking existing code which uses UART's for transferring arbitrary binary data - adds optional processor exception vector overloading with the
int-overloadmodule
Travis Bemann
