This release:
- implements support for the TRNG of the RP2350, to replace the use of
RANDOMBITon it. This provides significantly higher-quality random numbers than before. Note though that this is slow, andrng::randomshould not be used directly for generating arbitrary numbers, but rather is useful for seeding a PRNG such as TinyMT32 (which is included with zeptoforth). - adds a build script,
utils/build_picocalc_zeptoip.sh, for building zeptoforth on the PicoCalc with zeptoIP and the CYW43439 driver included. Note that the CYW43439 firmware is not in the zeptoforth repository for licensing reasons. - adds an optional I2C CH1116 display driver.
- adds an optional NTC thermistor driver.
- adds support for reverse text and selecting default foreground and background colors in
ansi-term. - fixes a bug shared between
extra/rp_common/picocalc_screenshot.fsandextra/rp_common/picocalc_screenshot_text.fswhere they would not compile on the RP2040. - fixes a bug in the text-only PicoCalc terminal emulator where the last line of each character would not be rendered properly.
Travis Bemann
