This release:
- adds single-core builds on the RP2040 and RP2350 to enable executing arbitrary code on the second core alongside zeptoforth on the first core; note that only the kernel binaries are included in the release tarball, and if the user desires to use these builds in practice they will need to build the remainder themselves.
- adds the ability to
postponenumeric literals. - adds
]]...[[to eliminate explicit calls topostpone(note that local variables cannot be used here). - adds
cycles::cycle-counterto give a cycle count on non-ARM Cortex-M0+ platforms (i.e. non-RP2040 platforms); note thatcycles::init-cyclesmust be called beforehand to start cycle counting and initialize the cycle count to zero.
Travis Bemann
