This release:
- breaks the core PicoCalc terminal emulator task, which polled for IO, into three tasks, one for input, one for output, and one for screenshots, which all block, resulting in lower CPU usage at the expense of somewhat higher SRAM usage.
- fixes the escape key combos generated by some of the function keys in the PicoCalc terminal emulator.
Travis Bemann
