Patch-level release 0.36.5
05/28/2022 at 02:18 • 0 commentsTurned off XON and XOFF by default (turning them on now requires setting
xon-xoff-enabled
to non-zero) and made a fix to the chronic build issues by changing howmake_image.sh
andmake_uf2_image.sh
decide to finish downloading ihex-formatted images from the MCU. -
Bug-fix patch-level release 0.36.4.1
05/27/2022 at 14:22 • 0 commentsThis bug-fix patch-level release fixes an issue where the entirety of the full build on the RP2040 was not getting built properly, so words such as
edit
andrestore-state
were not getting incorporated into the full build binary and UF2 file. Only the full build for the RP2040 has been rebuilt, and the reported version numbers in the kernel remain at 0.36.4. -
Patch-level release 0.36.4
05/22/2022 at 18:58 • 0 commentsThis patch-level release fixes a bug in upload mode in the line editor, which in particular would cause it to lock up on the Raspberry Pi Pico.
Patch-level release 0.36.3
05/21/2022 at 04:39 • 0 commentsThis patch-level release exposes more settings in the user-level
pio
module and also exposes speed settings in thepin
module. -
Patch-level release 0.36.2
05/19/2022 at 04:49 • 0 commentsThis patch level release fixes a number of issues with the
pio
module that rendered it not fully usable (e.g. sideset was broken). -
Patch-level release 0.36.1
05/17/2022 at 04:51 • 0 commentsThis patch-level release fixes an important set of bugs in the PIO assembler which caused the number of bits specified for
in,
,out,
,in+,
, andout+,
to not be assembled properly. Also, better documentation for the PIO assembler is included. -
Release 0.36.0
05/16/2022 at 01:52 • 0 commentsThis release revamps the API of the pio module for the RP2040 (i.e. Raspberry Pi Pico) to make it more user-friendly and to provide more validation of values passed to it.
Patch-level release 0.35.1
05/13/2022 at 03:37 • 0 commentsThis patch-level release fixes a major bug in queue channels that was preventing them from blocking properly under certain use conditions.
Release 0.35.0
05/12/2022 at 04:44 • 0 commentsThis release revamps the
pool
module's API and fixes an important allocation bug in it. It also adds optimizations to thepin
module on STM32 platforms. -
Release 0.34.0
05/11/2022 at 02:41 • 0 commentsThis release adds a new
pin
module that greatly simplifies interacting with GPIO pins and makes them as uniform as possible across all the supported platforms (the main differences being that on the RP2040 pins are simply GPIO pin numbers but on the STM32F407, STM32L476, and STM32F746 pins are expressed as a combination of a pin number on a GPIO and a GPIO). Additionally, it revamps theled
module to make it significantly more uniform across all platforms with LED's (for instanceon green led!
will turn on a green LED on the Raspberry Pi Pico, the STM32F407 DISCOVERY, and the STM32L476 DISCOVERY whereas previouslyled-on
was used on the Raspberry Pi Pico whileled-green-on
was used on the STM32F407 and STM32L476 DISCOVERY).
