The basic PC Gameport provides connection for up two controllers with 2 axes and 2 buttons each.
To measure the potentiometers using the Arduino, there are two possibilities:
- Adding a capacitor on each axis and measuring the time just like the PC does.
- Using the ADC altogether with external pulldown resistors.
First method provides a more precise method but requires a protection resistor and a timing capacitor for each axis.
void samplePCjoystick() {
static volatile uint16_t counter=0;
uint8_t sample;
a1X=0; a1Y=0; a2X=0; a2Y=0;
releaseCaps();
delayMicroseconds(5);
counter = 1024;
do { // sample inputs with time constant loop
sample = ~PINC;
delayMicroseconds(3);
a2Y+=sample & 1;
sample>>=1;
a2X+=sample & 1;
sample>>=1;
a1Y+=sample & 1;
sample>>=1;
a1X+=sample & 1;
} while (--counter);
// reset caps
holdCaps();
The second method requires only a pull down resistor but provides a non-linear curve that must be linearized.
int8_t PCJoy::_adcTo100(uint16_t adc)
int32_t retval = ((int32_t) 79794 / adc) - 178;
if (retval < -99)
return -99;
else if (retval > 99)
return 99;
else
return retval;
That will return a value within -99 to 99.
