I have just uploaded the Atari 2600 firmware. It can work with
The schematic is a mix of the Sega controller with PC controller in the sense that it uses a DB-9 and two RC networks.
The Driving controller uses a variable step. The faster you move it, larger are the steps.
// modulate the value of wheelStep to reflect the velocity that the wheel is being spinned
timeNow = millis();
deltaTime = timeNow - lastTime;
lastTime = timeNow;
if (deltaTime < 2 )
wheelStep = 8;
else if (deltaTime < 6 )
wheelStep = 4;
else wheelStep = 1;
I don't have a steering controller but used an ordinary encoder to test the code.
And here is the prototype. The paddles are DIY
