The Microsequencer is causing gnashing of teeth. ( I've updated the diagram/tables in previous log wit the corrected correction fix, revised. )
But now most signals work - ie they match my intended flow from the post "Block diagram". Time will tell if that works.
Still missing is LDO and LDP signals, but they're easy.
