I have now finished the build of the second generation fpga based vacuum robot .
The following improvements were made:
- Higher suction power due to better sealing
- Webapp with several cleaning functions
- Lower height of about 7 cm => doesn't get stuck under low furniture so often anymore
- 50 min charging duration by using LiPo- rechargeable battery
- Improved navigation algorithm (still chaos principle)
- Staircase detection through cliff sensors
- Low battery alarm and automatic shutdown (using a comparator IC instead of an ADC)
Here are some pictures of the new vehicle:
