Here is a link to a very similar project box:
https://www.ebay.com/itm/2-Way-Waterproof-Electrical-Junction-Box-Cable-Connector-Wire-IP68-Outdoor-KD/312823933067
A 6m dipole made for less than $30!
I got the proper connectors to connect the antenna to my NanoVNA netwrok analyzer so I could start tuning the antenna. My plan it to tune it to 52MHz and hope that the copper pipe gives me enough bandwidth to keep under 1:1.5 SWR across the entire 6M band: 50-54MHz. I left the pipes long so I could trim them down until I get to the right length.
Before tuning, this is what my NanyVNA is reporting:
As you can see, that 0.50in changed the resonant frequency to about 42.5MHz or 1.5MHz per 0.50in. My -15dB signal loss bandwidth has stayed within desired parameters as well!
Next I cut off an entire inch from each pipe, expecting the new resonant frequency to be about 46Mhz and lo:
My prediction was not correct! I continued to make cuts in this fashion until I hit the sweet spot at 52MHz. In making these cuts, I found that having the slightest variance in length between the pipes made a big different in the reflected power. 1/8" longer on one pipe changed my VSWR from 1.09 to 1.22!
In the end I decided to settle after the following readings:
I had to cut the antenna a bit shorter than I had initially expects, and I think this is due to the length of the wires from the inside of the box, from the jack to the pipes.
I also noticed that the readings on my NanoVNA varied depending on the the position I was holding the antenna. I will do more analysis once I have it mounted, but I believe this is close enough to put on the roof tomorrow!
73 for now, will post more in the evening.
Well this is handy - I'm in need of a cheap antenna for 6 meters. Looks like the copper pipe is being anchored to the box with cable glands - correct?
