After I reflowed the first board yesterday night, I started programming today. First I burned the bootloader onto the board to dublicate the settings of the Arduino Pro Mini (8MHz, 3.3V), wrote a test code (kinda annoying via ISP to develope code) and set the RTC to the date & time on my laptop. Then I uploaded the code again via ISP.
Test code:
#include "RTClib.h"
#include <Arduino.h>
#include <U8g2lib.h>
#include <Wire.h>
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0);
RTC_PCF8523 rtc;
char daysOfTheWeek[7][12] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
int running_index = 0;
void setup () {
// Serial.begin(57600);
pinMode(5, OUTPUT);
digitalWrite(5, LOW); // Keep device switched on after PWR button was pressed
u8g2.begin();
rtc.begin();
if (! rtc.initialized()) {
// Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
// rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
void loop () {
DateTime now = rtc.now();
if(running_index < 2) {
u8g2.clearBuffer();
u8g2.setFont(u8g2_font_logisoso28_tr);
u8g2.setCursor(0, 32); // Seperate cursor position from print statement
u8g2.print(now.hour());
u8g2.print(":");
if(now.minute() < 10) u8g2.print("0");
u8g2.print(now.minute());
u8g2.print(":");
if(now.second() < 10) u8g2.print("0");
u8g2.print(now.second());
u8g2.sendBuffer();
if(running_index > 1 && running_index < 3) {
u8g2.clearBuffer();
u8g2.setFont(u8g2_font_logisoso22_tr);
u8g2.print(daysOfTheWeek[now.dayOfTheWeek()]);
u8g2.print(" ");
u8g2.print(now.day());
u8g2.print(".");
if(now.month() < 10) u8g2.print("0");
u8g2.print(now.month());
u8g2.print(".");
u8g2.sendBuffer();
delay(1000);
running_index ++;
if(running_index > 3) {
u8g2.setPowerSave(1);
pinMode(5, INPUT); // Switch device off
M. Bindhammer
