Final prototype with triggered inputs
A project log for FED0
bare bones open source pellet dispenser
lex-kravitzLex Kravitz • 05/16/2020 at 02:48•0 Comments
I finished this prototype today and mounted everything on a permaboard.  I updated the code to include two triggers, either triggered from the buttons on the board, or a TRRS input jack.  Here is the final design working.  The pellet dispenser has two inputs.  When the first is triggered it attempts to dispense a pellet until it detects one with the photo-interrupter.  When the second is triggered it moves a servo to open a trapdoor to remove the pellet.
The Neopixel on the Adafruit Feather M4 also displays some status information:
Green: All good, monitoring inputs
Red: Dispensing
Blue: Moving servo
Green with red flash - Pellet dispenser encountered a jam and needed to clear itself
The next step is a custom PCB! here's a sneak peak:
