Hackaday.io Hackaday.io
Sign up Log in
Raspberry Pi Based SSD1306 OLED Video Player
I've used a Raspberry Pi running OpenCV on Python to play videos on an SSD1306 OLED Display
souvikssahasouvikssaha
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 2
    • View all
  • Logs 0
  • Instructions 3
    • View all
  • Discussion 0
View Gallery
754
0
2
1
Team (1)
  • souvikssahasouvikssaha
Join this project's team
  • GitHub Repo
  • YouTube Demo
Software
ongoing project
python raspberrypi opencv oled SSD1306
This project was created on 04/22/2020 and last updated 6 years ago.
Description
Using some basic image processing on OpenCV, I was able to convert the image to greyscale, resize it to 128x64 resolution and threshold it into the required Black and White format. I downloaded a movie clip from YouTube and saved fed it to the program and it worked!
The only issue I'm facing is the extremely slow frame rate but apart from that, it's a nifty tool that does serve its' purpose very well. I'm looking for ways to optimize the process and increase the frame rate. I am open to suggestions and hoping you all like
Components
  • 1 × Raspberry Pi 2B Any Raspberry Pi should do
  • 1 × OLED Display SSD1306
Build Instructions
Collapse
  • 1
    Install the modules for the OLED display using the link below
    https://www.raspberrypi-spy.co.uk/2018/04/i2c-oled-display-module-with-raspberry-pi/
  • 2
    Install OpenCV from the link below
    https://www.pyimagesearch.com/2018/09/19/pip-install-opencv/
  • 3
    Clone the repository oled-video-player and run oled-viewer.py
View all 3 instructions
Log In/Sign up to comment
Sign up with Github
OR
Raspberry Pi Smart Cam using AWS for image classification. Basic implementation but has an endless amount of potential for building on.
Project Owner Contributor
Raspberry Pi Smart Cam (Basic)
enriqueEnrique
Supplyframe DesignLab: 2022 Hackada…
A small project that allows running fullscreen versions of Mac OS 7/8/9 with sound, online connection and modem emulation under Raspberry Pi
MacintoshPi
jarosaw-mazurkiewiczJarosław Mazurkiewicz
Easy timelapse creation with the raspberry cam and automatic upload to youtube
raspilapse
minwiminWi
MiFrame is a Python Smart Photo Frame application. Supports sharing database across multiple frames, marking favorites, thumbs up etc
MiFrame - Yet Another (Raspberry) Pi Smart Frame
tklenketklenke
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Raspberry Pi Based SSD1306 OLED Video Player", please tell us the reason.
Send message
Remove Member
