4/12/2020
To compile #Sargon using the original TDL Macro Assembler, I will run an emulation of CP/M using MyZ80 inside DOSBox. Two levels of virtualization! MyZ80 supports import and export of files. Hopefully I can setup a properly memory mapped HEX file for the #RC2014
