8-bit PIC based thermometer with USB connectivity
Teplomer.X.zipSource codex-zip-compressed - 2.11 MB - 10/15/2022 at 18:29 |
thermometer.schsch - 740.72 kB - 04/25/2020 at 17:07 |
thermometer.brdbrd - 269.66 kB - 04/25/2020 at 17:07 |
Thank you Gabriel! I'll definitely try what you suggest.
PCB was made at Seeedstudio and i used MCP2200 as USB<->UART bridge and XC8.
nice build! I love to see other PIC builds here. I got a few questions for you if you dont mind: what pbc fab house did you use? What Usb stack/compiler?
Also, as a suggestion, you could cut some "smoked" acrylic squares about the same thickness as the enclosure and press fit them over the 7 segments. Makes it much easier to read. I wish i could upload a pic to show you mine on this comment.
