Sadly I'm still waiting for my FEP film to get my printer up and ready. While I've been waiting I've been making improvements and new creations.
####### Improvements #######
- Improvements made on the common module frame to strengthen it.
- Improvements made on the Display frame which allows for easy display swap out and also accepts the panel system.
####### New Creations #######
- Side Module Connection Pack: Easy connection interface to the module to add additional features.
- Side Module Click Pack:
- Once connected to the connection pack this module adds two mechanical switches and RGB LED to the module.
- The button caps can be removed and changed to suit the panel set added and or user preference.
Once I receive my 3D printer parts I'll finally be able to fully build and test some modules as a complete item..
