Parametric 3D Printed Cylindrical Coupling
Used as a base for assemblies, just put in your parameters and export the STL
Public Chat
I found myself needing these sorts of couplings regularly for work. To save designing them every time I spent an afternoon designing this model to be parametric. Download the files, open them in Solidworks and go to the equations tool (just search equations in the search bar at the top).Use the reference PDF to see what each relates to. Recommended clearances depends on your printer, but start big and work smaller. if you cant get a tight fit "up/down" print out a circle 1 layer thick at your working OD to take up some space. Male part prints with support.Video Explanation here:
https://youtu.be/--vyrE49Nc4
And a video of "one of" the uses. Used to house most of the electronics for a drone, allowing different bodies to be tried without having to de-solder and remount everything.
Coupler_CB.SLDPRT
sldprt - 438.11 kB - 04/28/2020 at 16:16
Download
Coupler_Drawing_CB.SLDDRW
slddrw - 243.38 kB - 04/28/2020 at 16:16
Download
Drawing_Coupler.PDF
Adobe Portable Document Format - 116.42 kB - 04/28/2020 at 16:16
Preview
jrpmedia wrote 03/28/2021 at 10:02 point
This is Great! :-)
But, we don't all have SOLIDworks, especially if we are Mac :-(
I don't seem to be able to use it in FUSION360.
Is there another way to use this, or maybe in FreeCAD.?
Thanks.
