Motor theory and practice
I use brushless 5010 motor rewired as stepper motor with 28 steps per revolution, controlled by L298N module, arduino and 2 hall effect sensors
Image bellow is a 3 phase brushless motor (5010 model) with 14 magnet poles and 12 stator poles, this motor need to be rewired as stepper motor with 28 steps per revolution
![](https://cdn.hackaday.io/images/6649461588211345263.jpg)
Motor wiring diagram (14 magnet poles, 12 stator poles) converted to stepper motor (top view)
NOTE: Arrows lines is always on top of stator lines
![](https://cdn.hackaday.io/images/7194311588141585622.png)
Motor phases animation with wiring above visualized in video bellow
Disassembled motor ready for rewire
![](https://cdn.hackaday.io/images/1996391588210684242.jpg)
I use small radius PTFE tube as a helper for rewiring
![](https://cdn.hackaday.io/images/5387211588210806199.jpg)
100 turns per pole by 28 AWG wire (very challenging process)
Final resistance 3.7 Ohm per phase
![](https://cdn.hackaday.io/images/3641061588210873718.jpg)
Assembled motor (wires covered by nail polish (pole 1 marked by blue)
![](https://cdn.hackaday.io/images/2075081588211229002.jpg)
Motor base plate 3d Printed (small holes for hall effects sensors mounting)
![](https://cdn.hackaday.io/images/803481588368377733.jpg)
2 Hall sensors ready to be mount on base plate (49E 9148G sensor)
![](https://cdn.hackaday.io/images/6448721588368517618.jpg)
Sensors mounted to base
![](https://cdn.hackaday.io/images/1777711588404071637.jpg)
Motor mounted to base plate 1st hall sensor look at stator pole 12 2nd to 9 (it should be 90 degrees)
![](https://cdn.hackaday.io/images/9495811588409921509.jpg)
Sensorless motor test run
Sensored test run
Motor torque test
- 160 PWM - 70g/10cm or 700g/cm
- 255 PWM - 160g/10cm or 1600g/cm
