Hackaday.io Hackaday.io
Sign up Log in
MakePython nRF52840
BLE 5.0 nRF52840 Solution, for CircuitPython/MicroPython/Aduino Learners
makerfabsMakerfabs
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
431
0
4
4
Team (1)
  • makerfabsMakerfabs
Join this project's team
ongoing project
Related lists
CircuitPython
All projects using Circuit Python go here!
This project was created on 04/30/2020 and last updated 6 years ago.
Starting from
Buy on Tindie
has orders / reviews
Ships from
Description
BLE 5.0 nRF52840 Solution, for CircuitPython/MicroPython/Aduino Learners.
A generic BLE MCU module target to CircuitPython/MicroPython learners & developers. It is true “breadboard compatible”, with the very detailed pins explanation, it is easy to learn& use. The nRF52840 is ready to take advantage of the considerable performance improvements for Bluetooth Low Energy (LE) with the arrival of the Bluetooth 5 specification. Of greatest importance is the support for longer range (up to x4 compared to Bluetooth 4.x) and doubling of on-air data rate, up to 2 Mbs from 1 Mbs in Bluetooth 4.x.
This MakePython nRF52840 programmed with CircuitPython by default, users can begin the CircuitPython developing as getting them on hand. It is also compatible with the Arduino making it easy to get started if the correct bootloader downloaded.
* Adafruit CircuitPython Pre-Loaded;
* Breadboard compatible
* Arduino
Details
Files
MakePython NRF52840 V1.1.sch
sch - 308.24 kB - 04/30/2020 at 02:37
Download
MakePython NRF52840 V1.1.brd
brd - 458.77 kB - 04/30/2020 at 02:37
Download
Log In/Sign up to comment
Sign up with Github
OR
Convenient plug and play LoRa enabled Arduino Shield. Search "PlugAndPlay For LoRa®" in the Arduino libraries manager.
Project Owner Contributor
chris-schornChris Schorn
Arduino @ PlatformIO for Mediatek MT6261, MT250x
MT6261 - Old chip - New Life
georgi-angelovGeorgi Angelov
Gritty monophonic 16-step sequencer.
Arduino Lo-Fi Synth
roland-metivierRoland Metivier
We interface an Arduino with an A7672S to build a GPS tracker that's fully functional.
A7672S with Arduino: GPS without Wi-Fi
electroscope-archiveElectroScope Archive
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MakePython nRF52840", please tell us the reason.
Send message
Remove Member
