This webUI is specifically designed to dynamically connect to a WiFi AP using the browser.
Usage
- Connect to Access point created by the Raspberry Pi.
- Open up a browser and navigate to http://raspberrypi.local:5000
- Fill up the
SSIDand thepsk - Click the connect button. Wait for some time(2-3 minutes). Pi will restart itself and now it is good to go!
Dependencies
How to use
- Navigate to the
webuidirectory usingcd webui - Run the command
sudo python <a target="_blank" rel="noopener noreferrer" href="http://app.py">app.py</a>
You can set the server to auto-start on boot using systemd
Tejas Lotlikar
