Not sure if it's clear, but there is a "sprite" near the keypad indicator on the display the screen is rendering much smoother than before after setting up the settings for the TFT_ILI9163C Library. In my current design the screen needs a manual reset by jumping the RES pin to ground easy to do with the usb connector casing or some wire.
