ST25R95 based evaluation platform for Node.IT
This is a project description for an easy to use evaluation module for the ST25R95 NFC controller chip based on our Node.IT platform.
0 followers
I need a simple platform for testing ST Microelectronics NFC chip ST25R95 that we are using in an upcoming project. Now I normally like to make a sample project based on the parts that we are going to use but this time I wanted to lift the NFC part out of the project and make a small break out board that would fit our own Node.IT based boards.
Node.IT is a super simple concept that I developed a few years back and successfully Kickstarted. Modules from this series can be found in our Tindie shop.
NFC3One.pdf
First version of the schematic
Adobe Portable Document Format - 22.59 kB - 05/02/2020 at 21:58
Preview
