A little bit of Led art using a light Logic sequencer
I had forgotten that I had this wood salvaged from the last hurricane.
Just a little more fun with the Starburst Ring Oscillator / Sequencer circuit but just as simple wire art with a hypnotic ring of leds :-D
I finally sketched out the circuit for the seven step sequencer for Starburst. This circuit is a closed loop except for the switch and that is only needed if the circuit does not start on its own when power is applied. Note the circuit outputs step by five, not sequentially.
Pretty much a single large entry as this was a quick and dirty art project. Enjoy the short video and images on how this all works as a unit. Keep i mind that no relays, transistors or IC's are used for the switching.
Give me a cardboard box and I am happy ;-)
