# ESP32-CAM-MJPEG-Stream-Decoder-and-Control-Library
ESP32-CAM is an inexpensive MJPEG stream embedded device.
The library is MJPEG stream decoder based on libcurl and OpenCV, and written in C/C++.
## Firmware
Modify the following code in "CameraWebServer.ino" file, that is MJPEG stream boundary.
```cpp
#define PART_BOUNDARY "WINBONDBOUDARY"
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\n\r\n";
## Easy-to-use
### Dependence
- OpenCV 3 or 4
- libcurl 7
- wxWidgets 2.8.12(for wxESP32-CAM example)
### Use
Include "ESP32-CAM MJPEG Library" folder into your project. </br>
- ESP32-CAM Library.h
- ESP32-CAM Library.cpp
```cpp
#include "./ESP32-CAM MJPEG Library/ESP32-CAM Library.h"
typedef enum {
FRAMESIZE_QQVGA, // 160x120
FRAMESIZE_QQVGA2, // 128x160
FRAMESIZE_QCIF, // 176x144
FRAMESIZE_HQVGA, // 240x176
FRAMESIZE_QVGA, // 320x240
FRAMESIZE_CIF, // 400x296
FRAMESIZE_VGA, // 640x480
FRAMESIZE_SVGA, // 800x600
FRAMESIZE_XGA, // 1024x768
FRAMESIZE_SXGA, // 1280x1024
FRAMESIZE_UXGA // 1600x1200
} framesize_t;
ESP32_CAM *esp32_cam = new ESP32_CAM(std::string( "192.168.1.254" )); //ESP32-CAM local IP address
esp32_cam->SetResolution(FRAMESIZE_SVGA); // Set mjpeg video stream resolution
esp32_cam->StartVideoStream(); // Start mjpeg video stream thread
cv::Mat frame = esp32_cam->GetFrame(); // Get mjpeg frame
if(!frame.empty()){
cv::imshow("Example",frame); //Show mjpeg video stream
### Command POST and ESP32-CAM GET
In cmd_handler, "var" is variable name, "val" is value of variable, curl POST command is:
```cpp
int ESP32_CAM::SendStream(CURL *curl_object)
long return_code;
CURLcode response;
curl_easy_setopt(curl_object,CURLOPT_URL,"192.168.1.254/control?var=framesize&val=7");
response = curl_easy_perform(curl_object);
response = curl_easy_getinfo(curl_object, CURLINFO_RESPONSE_CODE, &return_code);
return (int)return_code;
"192.168.1.254/control?var=framesize&val=8", "192.168.1.254" is ESP32-CAM IP address setting from:
```cpp
// Set your Static IP address
IPAddress local_IP(192, 168, 1, 254);
// Set your Gateway IP address
IPAddress gateway(192, 168, 1, 1);
WiFi.begin(ssid, password);
WiFi.config(local_IP, gateway, subnet);
In this example, "/control?var=framesize&val=8" POST /control API and set parameter "framesize" value is "7"(FRAMESIZE_SVGA 800x600).
API FlashControl(bool), Flash LED turn on or off "/led?var=flash&val=1", val=1 is on, val=0 is off.
### Receive ESP32-CAM Page Content
Set curl_easy_setopt parameter CURLOPT_WRITEFUNCTION and CURLOPT_WRITEDATA for writing received data.
```cpp
std::string ESP32_CAM::GetRSSI()
std::string buffer;
curl_easy_setopt(curl_command,CURLOPT_WRITEFUNCTION,WriteCallback);
curl_easy_setopt(curl_command,CURLOPT_WRITEDATA,&buffer);
if(SendStream(curl_command,std::string("/RSSI"))){
return buffer;
### MJPEG Stream Format
In this case MJPEG stream boundary is fixed length, for split into a MJPEG stream of JPEG binary(byte), each frame JPEG binary with cv::imdecode decode to RGB format. </br>
```cpp
const char VIDEO_STREAM_INTERLEAVE[] = "--WINBONDBOUDARY\r\nContent-Type: image/jpeg\r\n\r\n";
const char JPEG_SOI_MARKER_FIRST_BYTE = 0xFF;
const char JPEG_SOI_MARKER_SECOND_BYTE = 0xD8;
```cpp
Content-type: multipart/x-mixed-replace;...
GCY
myembed
kc1r74p
