No matter what function your ESP8266 might have, it is quite likely that you want to change some settings or parameters while the device is in use. Like for example the speed of a motor, or the color of a LED. The configuration manager presented here provides a method to easily define these tuneable parameters in a JSON file. The code to change parameters from the browser and store them into EEPROM memory is generated automatically.
Maakbaas
