Found a minor hiccup with the lamp I made. This morning when the sun was beating down on it the shaft seemed a bit too wobbly. I think it is down to the glue. Aiming for the "don't buy anything" goal meant I didn't have much fast drying wood glue to work with. It would have taken months to assemble if I had used the wood glue I had on hand. So I used hot melt glue for a lot of it. The bits where I used wood glue are solid, but the hot glue flexes a little and flexes more when warm. I'm still pretty confident in the design if assembled with a glue that dries hard, but I'm not about to disassemble it to replace the glue. Instead I took the handle from a broken rake, cut it to length, painted it black, and glued it to the inside of the shaft. Now it's a lot more stiff.
Again, I'm 99% sure this is down to the hot glue given that the issue is a lot more obvious when sitting in the Florida sun on a hot day in a room of windows with no air flow or AC, but thought I should mention it.
