This device is under construction.
It gathers all GPS data, 8 different gas concentrations, air pressure, humidity and temperature. The Hardware is done and working. The gas-sensor data is calculated into ratios, but i'm still on the logarithmic conversion for 'ppm' / 'ppb' values. The power consumption is high and i only use three 7805 regulators on heat sink. I dont like it too much, but it works.
H2, CH4, CO, CO2, Ethanol, LPG, Benzine, Hexan, propane.. there are cross sensitivities for a few of the used sensors and every sensor detects more than one gas. One Sensor has a high sensitivity to one of those gases. In theory more gases then sensors available could be detected.
What gases to those sensors cover?
