I've now posted some boot rom sources and added the 68HC11 to the Fuzix platforms. With the current git head you can now run Fuzix on the HC11. I've not done anything fancy with the I/O beyond supporting an SD card on the SPI and using the internal serial port. All the basic RC2014 external devices work such as the IDE adapter.
EtchedPixels
