The memory allocator works the way I want it now. Here's an example with all commands run in basic.
REM load 4 threads via serial port tload1 tload1 tload1 tload1 REM print info about the threads Thread nr Slot time Blocks 0 20 1 2 3 4 5 6 7 8 1 10 9 2 10 10 3 10 11 4 10 12 REM kill 2 threads tkill1 tkill3 REM load a 64KiB thread tload8 REM raise slot time for thread 0, ehBasic tslotw0,80 REM print info about the threads Thread nr Slot time Blocks 0 80 1 2 3 4 5 6 7 8 2 10 10 4 10 12 5 10 9 11 13 14 15 16 17 18
Killing thread 1 & 3 creates holes in the block-pool. Thread 5 gets non-consecutive blocks allocated, but it does not matter because the memory is run in the linear 64KiB CPU-space. Banked memory can be good to get rid of memory fragmentation problems.
In other words, I've got (simple) virtual memory management in place :)
