Latest improvement: battery and power/charge circuitry so that PZ1 for the first time is a truly stand-alone laptop! It was a while since I measured the power requirements, but based on those old numbers (~1.5W) the battery should last at least 12h.
I also took the opportunity to zip-tie everything.
