On holiday, but still coding in a few spare timeslots :)
The added SD-card reader works, files on FAT16/32 can be used now.
EhBasic with multitasking starts, still needs some more testing.
65C02 runs @1MHz with everything enabled on 133MHz Pico. SID emulation and mixing at 44100Hz, no filters. Only core 0 used so far. PIOs could probably be used to offload a significant amount of load by reading/writing the buffers.
Looking bright!
Now all the work left to get this up to snuff for a GitHub release.
