I printed some tenting stands I found on github and I love the way they turned out. The ED case is held together with M3 bolts, and the bolt heads on the bottom sit nicely inside the three holes in the stand. They don't slip around very much, but I'll probably get rubber feet at some point, both for the stands and to keep the rest of the bolt heads from scratching things.
