I do have spare protoboard, however this build is mostly hooking together other modules and breakout boards with very few through hole components. So I thought I'd save my scarce resources by using crafting lolly sticks to hold everything together..
This is enough to test whether the concept would work before I solder the microcontroller and program it.
