This speaker sounds great so it was a disappointment when it died. Bringing it back wasn't so straightforward. The internal battery pack is a shrinkwrapped pack of two lithium 18650s. The protection circuitry is on the board itself, so without a valid (narrow) range of voltage on that connector the board will not power up.
It didn't look very straight-forward to bypass the protection circuit. So I threw the disassembled thing in a storage box and let it sit for a couple of years. Wanting to get my workshop cleaned out I grabbed it today and set to work. I removed the battery from where it was stowed beneath the board, and clipped the leads:
I put the bench supply onto these two leads at 7.4 V and 1.5 A and the speaker came to life no problem. I searched in my parts bin for an adequate power supply. I had some 9 V wall warts but their current output was far too low. What to do? Well, I wanted to use it in the workshop, why not just power it from the bench supply?
There was just enough room in the case for the banana sockets. I just crimped on a couple of connectors to the cut leads from the battery. Before reassembling I disconnected the cable to the USB charging port (still shown connected here). It would be bad to try and charge whatever connects to these banana plugs (although I suppose I could use this as an external 18650 charger...
Looks pretty good, and still sounds great!
My bench is still a mess, but this freed up a storage box to help with the organization efforts. By hook or by crook, my workshop will by tidy by the height of summer this year!
Mike Szczys
How do you like that bench supply? I'm in the market, and Father's Day is coming up...
